Save 20% off all Chaos products! Get early access.
03
18
09
30
Early access to the best deal of the year.
Save 20% off your new annual V-Ray license.
This update lets you seamlessly match real-world scans to your 3D scenes with Gaussian Splat relighting, and accelerates your creative process with AI-powered ideation, enhancement, image-to-video generation, and more via a new integration with Veras. Designed to fit any pipeline or hardware configuration, update 4 empowers you to deliver pixel-perfect final frames with maximum efficiency and optimized rendering performance for both CPU and GPU. Complex looks and stunning effects are within effortless reach thanks to intuitive, artist-friendly workflows and tools, including initial native Bifrost Graph support.
Create worlds. Light them perfectly.
Pre-production
Match real-world environment scans to your 3D scene’s lighting.
Gaussian Splats relighting
Blend Gaussian Splats beautifully and naturally into any environment with seamless real-world scan integration via splat asset relighting. Easily match a Gaussian Splat’s lighting to your scene, making it effortless to blend captured locations, especially those scanned under ambient lighting, directly into your 3D worlds. From early-stage previz to final production, you can freely adjust your scene lights at any time without wasting hours working around baked lighting.
AI-powered creative ideation with Veras
Stuck at the ideation stage, or need to refine a scene before a presentation? Veras brings AI-powered ideation directly to V-Ray and Vantage. Start with a basic block-out render from the viewport, and upload a drawing or a reference image. Using presets or custom prompts, instantly generate multiple concepts, styles, and camera variations for inspiration. You can also refine renders in post to try new artistic styles, or generate matching asset backgrounds for set extensions. Keep your entire creative process in one seamless workflow, without switching tools.
Faster rendering on any setup, for any look.
Production
Deliver pixel-perfect shots with maximum efficiency, regardless of your pipeline or hardware configuration. Bring your ideas to life with tools that make complex looks and stunning effects effortless to achieve.
Even faster time to first pixel
Experience highly responsive rendering with a significantly faster time to first pixel. V-Ray GPU IPR now starts up to 2x quicker, thanks to accelerated asset uploads to VRAM and faster texture compression.
Profile-Guided Optimizations (PGO)
Get up to a 13% performance gain in CPU rendering, thanks to our switch to the Intel® ICX Compiler and the implementation of Hardware Profile-Guided Optimizations supported by Intel® Core™ Ultra processors. Speed up your workflow and experience best-in-class performance to maintain your creative momentum and meet even the tightest production deadlines.
Light Cache Denoising
Get cleaner, smoother rendering previews faster and enjoy a significantly improved interactive rendering experience, no longer having to look at a noisy image for long. By applying the denoiser directly to the Light Cache before the actual rendering begins, high-frequency noise is smoothed out instantly. This feature is enabled by default for the NVIDIA Denoiser, delivering better interactive feedback with zero extra setup required for users on the latest version of V-Ray.
Out-of-frustum displacement tessellation
Optimize your scene memory when rendering complex displacement and subdivision surfaces. Control and dynamically dial down the tessellation detail of geometry that falls outside the camera's view frustum, or in other words, objects not visible to the camera, significantly reducing memory usage, accelerating geometry compilation, and achieving faster render times without compromising visual quality.
Effortless artistic control
V-Ray Parallax Texture
Breathe life into massive cityscapes and background buildings while saving time on modeling and keeping your scenes light and fast to render. The V-Ray Parallax Texture lets you create the perfect illusion of fully furnished, beautifully lit rooms behind your windows using just textures instead of heavy 3D geometry. As your camera moves through the scene, the interiors shift dynamically to preserve a convincing sense of depth from every angle, letting you effortlessly dress vast environments so you can focus on the bigger creative picture.
Explore ready-to-use interior parallax assets in Chaos Cosmos>
Quick caustics
Enable the new, quick caustics in V-Ray to easily generate stunning light refraction patterns, bypassing the tedious, trial-and-error setup of the traditional photon-based workflow. Much simpler to control and significantly faster to render, a single depth toggle delivers believable underwater caustics without the high performance cost of full photon tracing. The result is realistic caustics with minimal effort, making complex light simulation accessible, predictable, and highly practical for every artist and project.
Flexible, seamlessly integrated rendering
Support for the latest host app version
Whenever you’re ready to update your host platform to benefit from the latest features, you can do so with the confidence that you’ll maintain rock-solid rendering stability. V-Ray officially supports the newest Autodesk Maya 2027.
Initial* Native Bifrost Graph Support Title
V-Ray is now even more seamlessly integrated with Autodesk Maya, bringing initial support for Bifrost Graph nodes. This allows you to instantly render your procedural setups as V-Ray translates the Bifrost Graph nodes for you. You no longer need to worry about caching and re-linking, which previously only worked for some features—now, you simply hit render.
*See which features the initial support covers and which features are not yet supported here>
More control in compositing and AI-powered upscaling.
Post-production
Easily integrate CG elements with live-action footage, work with volumes effortlessly in post, and instantly boost the resolution of your final frames without re-rendering.
Working with volumes in compositing just got a lot easier thanks to Light Path Expressions (LPEs) for Volumes. Now you can easily isolate the light cast by smoke, clouds, or fog in your scene, or extract the self-illumination of a fire into a separate render channel, simplifying post-production for scenes with effects.
images
Get your free 30 day trial.
© Mohamed Alaa
Black Friday 2026
20% off all V-Ray plans
From Solo to Collection.
Get early access to the best deal of the year now!
