Desert scene rendered with Corona 5
Tom Grimes
Tom Grimes
Last updated: August 13, 2025  •  12 min read
Corona 5 for 3ds Max released
Summary:
  • Corona 5 offers significant memory and render time savings with features like 2.5D Displacement and Caustics Optimizations, enhancing performance without scene changes.
  • 2.5D Displacement reduces memory usage and parsing time, providing up to 10 times less memory usage in extreme cases, and is now the default method for new scenes.
  • Caustics optimizations allow faster rendering with less memory, and now respect light Include/Exclude lists for better artistic control.
  • Corona Material Library updates include new Hair and Skin materials, and various optimizations improve memory usage and performance across different features.
  • Corona Renderer 5 for Cinema 4D will soon be released, offering compatibility with R21 and bringing more features from the 3ds Max version.
A new version of Corona is now available. Click here to learn more.
Quick facts about Corona 5
  • Memory and render time savings right out of the box, without the need to change anything in the scene.
  • 2.5D Displacement – New default displacement calculation method, which gives you much faster scene parsing and even more memory savings.
  • Caustics Optimizations – Caustics render faster and use less memory, no changes needed to the scene.
  • General Optimizations – There are overall memory and render time savings, including for geometry processing and more.
  • ColorCorrect Optimizations – The performance of the Corona Color Correct map has been improved.
  • Hair – Corona now uses half the memory, and some artifacts have been removed.
  • Corona Material Library updated (17 new basic Hair materials, 10 new Skin materials, and some smaller fixes).
Corona for Cinema 4D
Just over a month ago, we added Cinema 4D R21 compatibility with the release of Corona Renderer 4 for Cinema 4D (Hotfix 3). We’re working hard on Corona Renderer 5 for Cinema 4D – naturally it will have R21 compatibility right out of the gate, and the optimizations listed here for the Corona core, but it will also bring greater parity with Corona Renderer for 3ds Max by adding some more features from the core into Cinema 4D, plus its own optimizations and bug fixes.
Major features of Corona 5
2.5D Displacement
“I AM IMPRESSED! I did a 5k render with the old displacement vs the 2.5D – memory usage went from 130gb to 60gb. For us at The Boundary, it already looks like it is going to be a game changer.” Peter Guthrie of The Boundary, on testing the Corona Renderer 5 daily builds
The new 2.5D Displacement will help you make the most of your RAM, offering substantial savings on memory usage. 2.5D Displacement is the default in all new scenes, and if you open an existing scene you can choose to instantly and automatically swap over and take advantage of those memory savings!
In the full-size comparison, you can see the render stamp for each render. Here, Corona Renderer 5 used around 24% less RAM, took 12.6% less render time, and all this with more detail in the displacement geometry.
2.5D Displacement allows the use of a smaller Screen or World Size value, which means more detail in the geometry created by displacement while still needing less memory.
Loading an existing scene will ask if you want to swap to this new displacement. If you choose yes, then the Screen Size value for the scene will be adjusted automatically – for example, if your existing scene had a Screen Size of 3, it will automatically be adjusted to a value of 2 (you can of course make further adjustments to it yourself if needed). If you manually set up the new 2.5D displacement, setting Screen Size to two thirds of its previous value is a good guide, the same as the automatic set up would do.
2.5D Displacement also offers significant savings on Parsing Time.
From our tests, we have found:
  • Geometry processing can be up to 3 to 4 times faster on average, but up to 20 times faster in some extreme cases
  • Rendering speed gets a few percent of an increase on average, but up to 3 times faster in scenes with heavy displacement
  • Uses only half the memory on average, but up to 10 times less memory in some extreme cases
Please note – all our tests and all feedback from users so far has shown that 2.5D displacement is far better than the old displacement. Unless we hear of any experiences that contradict this, we plan at some point in the future to remove the old displacement from Corona Renderer and leave only the 2.5D displacement.
Known Current Limitations:Using a CoronaLightMtl on an object which has 2.5D displacement may give undesired results – you can read this article for more information – 2.5D displacement does not work with the Fast mode of the Rounded Corners map (only where displacement is applied to the same object as a Rounded Corners map; Fast mode will still work for all objects without displacement applied, even if 2.5D displacement is enabled)
Caustics have been optimized, and you can simply load any existing scene and you will find it renders faster and requires less memory (or of course get those benefits in any new scene you create)
Prism-Trap-4-vs-5-comparison-side-by-side-02
The above prism scene (Adam Iwackowski, quadrays.com) is almost nothing but caustics, so we can narrow down the performance gains from the caustics improvements alone (rather than gains from geometry parsing, instancing, etc.). Here we see that Corona Renderer 5 saves 16% memory, and needs 31% less render time.
Caustics have also been improved with multiple lights:
In this example – also almost pure caustics – we see a 25% less RAM and 23% less render time required.
Caustics now also respect the Include/Exclude list of lights, so in addition to the usual effects of excluding an object from a light, that object will also no longer create reflective or refractive caustics from that light.
The Exclude list used in the CoronaLight
Conversely, if you create an Include list, then only objects in that list will generate reflective and refractive caustics from that light (in addition to the usual effects of adding objects to the Include list for the light).
This can be used for:
  • Artistic purposes, to get a desired result
  • Control over multiple objects that use the same material (rather than create separate materials with refractive caustics on and off)
  • Optimizations to render times by removing objects that generate some caustics which do not contribute significantly to the result (do keep in mind that you are excluding the object from ALL interactions with that light, not just the caustics aspects of that light – you could of course duplicate the light source, to have one “caustics only” light that only generates caustics for particular objects)
Corona Material Library Updates
17 new basic Hair materials and 10 new Skin materials were added to the material library:
Also, the tiling size of normal maps in the Oak Honey Floor and Oak Northland Floor materials was fixed, as was an inconsistent tiling size in the Stone -> Cobblestone Herringbone material.
Hair Optimizations
Corona now only needs half as much memory when rendering hair (Max native, Ornatrix, or Hair Farm). This translates into an overall 20% memory saving for the scene, once you add in the memory used by Max and the hair software. These updates also remove some artifacts.
Other Specific Optimizations
The performance of the CoronaColorCorrect has been optimized, and Bloom & Glare is now 10% faster and uses 20% less memory.
Overall Optimizations
We’ve done a lot of work on generally optimizing Corona Renderer. This includes things like a rewrite of the geometry processing, a switch to the latest Embree library, optimizing the calculation of mesh normals, optimizing geometry processing time and IR restarts in scenes with larger number of instances, and more.
These mean that all Corona Renderer scenes will be faster/need less memory (not just those using displacement or caustics).
Updated the NVIDIA GPU AI denoiser to the latest version
  • Better compatibility with other plugins which also use NVIDIA CUDA and OptiX frameworks
  • Improved performance with Turing GPUs
  • Better error reporting
  • Requires NVIDIA GPU driver version 418.81 or newer
  • Please note – NVIDIA has also removed support for Kepler-based GPUs, and their AI denoiser now needs Maxwell-based cards or newer. This is not something we can control of course, but we want all our users to be aware before installing. Conversely, in our tests some Maxwell-based mobile GPUs can now run the NVIDIA AI denoiser, where they couldn’t previously.
Smaller improvements
  • When a material with a RaySwitch map in the Diffuse slot is shown the viewport, the map from the Direct Visibility override is now displayed instead of the map from the GI override:
Material using RaySwitch
  • Improved text rendering in the Render Stamp We’ve used an improved font for the Render Stamp, which will make it easier to read in all images but especially on high resolution monitors. (If you want to change the size of the font, you can use the string options)
Legibility of the Render Stamp has been improved
  • “Setup LightMix” button added to the multiple environment maps dialog
  • Optimized the Corona Distance Map when Corona Scatter is plugged into it as a distance-from object. Brings up to a 30% speed increase in extreme cases
  • Optimized scene parsing time for scenes with a high number of instances, up to twice as fast in scenes with around 5 million instances
  • High Quality Image Filtering – moved from being a separate checkbox into the dropdown list of filter types
  • Changing render regions now resumes IR if it had previously stopped by hitting the IR pass limit
  • “[IR]” tag added to the VFB title bar, to show that the image was rendered with IR rather than a final render
  • Faster IR restarts in scenes with a CoronaSun (or more than one CoronaSun)
  • The Corona Color Picker now displays the Corona icon in its title bar
  • Added a help button to the Autosave path which explains the special tokens that can be used (similar to those used in the render stamp)
  • Copy clipboard option added to the CIE
  • Bloom & Glare progress bar now added to the CIE (just like the one already in the VFB)
  • Updated the Intel CPU AI denoiser to version 1.0 – this fixes the appearance of “ghosts” in the denoising for objects that are not visible in the scene due to a lack of lighting, and lowers memory consumption for higher resolutions (2K or higher)
  • Added a warning which is shown when there is a NaN (invalid pixel value) in the renderer image. This warning has a link to the helpdesk so that you can easily let us know about the problem by filing a bug report
  • Added “Unpacking and installing” message to the installer, so that you will know that something is still happening after the NVIDIA AI denoiser or the Material Library are downloaded
  • When doing an Unpack install, the Installer now detects when the selected directory contains any files, and asks if you would like to override them or cancel the unpacking
  • Changed the directory structure for the installation of Corona Renderer – we no longer install DLLs into the 3ds Max root folder, but instead install those to the Program Files folder
  • Added an option to disable the “Startup scripts enabled” warning in 3ds Max
  • Added support for SiNi Scatter
Bug fixes
General Fixes
  • Fixed wrong color of toggleable buttons
  • Fixed the Proxy “Hide out of range” animation option (it was hiding the proxy too early)
  • CXRs now saves information about the camera used at render time (VR, type, etc.) – This allows the CIE to computer Bloom&Glare correctly for different camera types (Note, this only applies to CXRs saved from Corona 5 and newer of course – existing CXRs will not have this information added to them retromagically!)
  • Fixed normals that were wrongly computed in some cases
  • Fixed radio buttons disappearing from different sections in the Corona Camera
  • Fixed .conf file parsing error on opening Render Settings or starting a render, which occurred after certain values were saved as defaults in the Render Settings (e.g. when Image Filter Type is set to Symmetric Tent by default)
  • Fixed not being able to reload a .conf file saved from the CIE, which happened in some cases (e.g. when the NVIDIA or Intel AI denoisers are selected)
  • Fixed Falloff map in camera space not reacting to camera movement
  • Fixed Corona Camera Tilt and Shift not being updated on opening a scene
  • Fixed the VFB stopping updating after drag and dropping LightMix colors
  • Fixed caustics disappearing with more passes in some scenes
  • Fixed the SSS material rendering wrong when inside glass with Refraction Glossiness of <1 when caustics were enabled for the glass material
  • Fixed the Corona Sky map not working correctly with multiple Suns in the scene
  • Fixed LayeredMtl layers affecting displacement
  • When LightMix is recreated using the LightMix setup dialog, the LightMix configuration (colors and enables) will be reset to defaults
  • Fixed using saturation -1 not resulting in completely grayscale image
  • Fixed autosave saving material editor renders
  • Fixed appearance of unwanted hard edges when rendering overlapping scattering media
  • Fixed pan & zoom rendering wrong offset when zooming in
  • Fixed .scn and .cxr file extension associations stopping working when the installation path to Corona Standalone or Corona Image Editor was changed from previous installation
  • Fixed IR freezing when using ProBoolean
  • Fixed artifacts when using a dark environment map
  • Fixed result being automatically saved to render history when the render is cancelled
  • Corona Color Picker now updates the color as soon as you start modifying the hexadecimal color representation
Crash Fixes
  • Fixed crash when switching a CoronaLight on or off during IR
  • Fixed 3ds Max sometimes crashing during parsing when the point cache modifier is used
  • Fixed crashes when loading malformed proxy files
  • Fixed crash when NVIDIA AI libraries cannot be loaded
  • Fixed crash when rendering the 3ds Max volume light effect (in atmosphere effects)
  • Fixed crash when opening some scenes using CoronaCamera auto tilt
  • Fixed crash when old displacement with water level is applied on an object with unusual geometry
  • Fixed rare crash when rendering an isolated object
  • Fixed random crashes when (de)selecting Corona objects, maps, and materials
Installer Fixes
  • Fixed installer reporting an incomplete size after successfully downloading the NVIDIA AI denoiser or the Material Library (e.g. “218.9 MB / 220 MB”)
Licensing Fixes
  • Fixed Corona so that it looks for the Licensing Server on all network interfaces
  • The “Activate License” button in the System tab of the Render Setup now does not need to be clicked multiple times to get it to activate
  • The System tab in the Render Setup no longer claims there is no license when one has been acquired from the Licensing Server
  • Fixed license activation not working in some cases when running Corona on the same machine as the Licensing Server
What's ahead
The Corona train never stops at any station for long! Now that Corona Renderer 5 is out, well be starting work on the next version – and of course, Cinema 4D users can look forward to the release of Corona Renderer 5 for Cinema 4D soon.
While Corona Renderer 5 was very much focused on optimizations, next time we’ll be turning our attention to pushing the feature set ahead once again. Things we are considering include a new grounds-up PBR material, a Slicer/Clipper material, reworking the tone mapping, and more.
As well as the Hair and Skin materials included with this release, we’ve also been creating more new materials for the Corona Material Library. Although we have many that are already complete, we are still putting the final touches to some. Once those additional updates to the library are complete, we’ll look at how best to release those (perhaps in the Corona Renderer 6 dailies, or perhaps as an update to previous Corona versions).
You can follow the timetable for our ongoing journey at the 3ds Max roadmap and at the Cinema 4D roadmap.
Download Corona 5
No need to scroll back up to the top of the post to download, here’s the link again for those of you dedicated enough to read everything first!
Download the latest version of Corona here.
Thanks!
There’s more to every Corona release than just the hard work the developers put in, so as well as our thanks to them, we also want to extend that to our support, business partners, forum moderators, translators, testers, advisors, partners, resellers, all at Chaos, and of course to you, our users, for supporting us and for letting us know what you want to see added!
So to all of you, we’d like to say….
Thank you!
Adam, Ondra, and the Corona Crew
Chaos logo apricot.
Share
Tom Grimes
Tom Grimes
Tom is the Product Manager for Chaos Corona. Before joining the team in 2016, he worked in the industry as a freelance 3D artist, programmer, and additionally worked for 10 years as a marketing specialist for other 3D software companies. He specializes in 3D illustration and animation.
Subscribe to Our Blog
blog-subscribe-large-cta-bg
