Admin
Last updated: August 12, 2025  •  2 min read
V-Ray Next for SketchUp is here
Summary:
  • V-Ray Next for SketchUp enhances speed and simplicity, allowing users to create high-quality ray-traced visuals with ease.
  • Automatic scene analysis and adaptive lighting improve performance, making the design process more efficient.
  • Key features include V-Ray Scene Intelligence, Adaptive Dome Light, and Auto White Balance and Exposure for optimized rendering.
  • The GPU renderer is over 200% faster, and the new Scene Interaction Tool allows interactive adjustments to materials and lighting.
  • Additional features like Lighting Analysis Tools and Metalness Material Properties enhance compatibility and visualization.
© David Santos
With V-Ray Next for SketchUp we’ve boosted the speed and simplicity of SketchUp’s premier renderer. Now, with a few clicks, you can create high-quality ray-traced visuals using one of the world’s most widely used design programs. Automatic scene analysis and adaptive lighting join dozens of new features, bringing more performance to the design process.
Backed by over four years of R&D, V-Ray Next rapidly accelerates the SketchUp workflow, building massive speed and intelligence gains under the hood, so designers can produce faster, cleaner renders with little to no extra effort. This latest version is also immediately compatible with the new SketchUp 2019, as well as versions 2016-2018.
Try V-Ray Next for SketchUp
Headline features include:
New V-Ray Scene Intelligence can now automatically analyze a 3D scene at the start of a render, optimizing some of the most common decisions you’ll make.
The new Adaptive Dome Light (ADL) offers more accurate, image-based environment lighting that’s up to 7x faster.
Finding the perfect camera exposure or white balance is no longer an issue. Once a scene loads, Auto White Balance and Exposure return the right settings, making the entire process point-and-shoot simple.
A new NVIDIA AI Denoiser has also been embedded, so you get automatic noise removal and clean updates as they work.
The GPU renderer is over 200 percent faster, accelerating nearly every V-Ray feature including fog and atmospheric effects.
A new Scene Interaction Tool now provides direct access to any level of the SketchUp hierarchy, so you can interactively adjust materials and light properties whenever an object is selected.
A new V-Ray Toolbar has also been included, providing new access to top tools and simplified UI controls that will make it easier to set up cameras, adjust render settings and manage scenes.
The new asset management system can help you find and track V-Ray assets, using a custom library that can be shared across SketchUp projects.
Additional Features Include:
New Lighting Analysis Tools - Now easier to visualize a scene’s real-world illumination values in lux or footcandles.
New Metalness Material Properties - A new addition to the standard V-Ray Material offers improved compatibility with Substance Designer and PBR materials.
Color Correction Curves - Fine-tune texture colors right in SketchUp without heading back to an image editor.
Material ID & MultiMatte Render Elements - Render 2D masks of 3D objects for quick fixes in Photoshop and other image editors.
Improved V-Ray Scenes and Materials Exchange - Fluid asset transfers from other V-Ray applications (Rhino, Revit and 3ds Max).
Find out more
Chaos logo apricot.
Share
Subscribe to Our Blog
blog-subscribe-large-cta-bg
