Corona 3D render of a modern chair showing material swap, half in tan leather and half in teal fabric.
Ina Iontcheva
Ina Iontcheva
Last updated: August 26, 2025  •  10 min read
Corona 12, update 2 brings Chaos Scans into Cosmos
Summary:
Corona 12, update 12 is now available. Access over 3,100 ultra-realistic scanned materials in Cosmos. Other highlights include immersive virtual tours with automatic hotspot generation, precise camera control with Per-Camera Global Volume override, improved texture filtering and depth of field, support for 3ds Max 2026, and new features in Corona for Cinema 4D.
Corona 12, update 2 is here! While this update focuses on technical enhancements, it also brings exciting new features that lay the foundation for what’s coming up in Corona 13. Explore over 3,100 ultra-realistic scanned materials in Cosmos, auto-generate virtual tours, and enjoy sharper, more natural-looking renders. Let’s dive in.
Chaos Scans are now in Cosmos
Finding the perfect materials for your scene just got even easier. Corona users now have direct access to over 3,100 ultra-realistic scanned materials, seamlessly integrated into the Cosmos library. No more switching between platforms or manual imports—everything is in one place, ready to drag and drop straight into your scene. Premium users also have the added benefit of editing these scanned materials, offering full control to tailor them exactly to project needs.
The Chaos Scans materials span a wide range of categories like metal, leather, paper, plastic, and rubber, including 380+ brand-new additions. And because they’re Cosmos assets, you can now import multiple materials at once to speed things up even more.
As a bonus, the library includes high-end scanned materials from trusted names in luxury packaging and design, such as Eska, Winter & Co, Foilco, and premium leather textures from Foglizzo.
"Chaos Scans are awesome materials that respond to light in ways you can't achieve by using bitmaps in other materials. Those are now easy to find and import as they are right there in Cosmos - plus, there are 200 new archviz-focused Scans being added too!"
Tom Grimes, Product Manager, Chaos
Explore the Chaos Scans materials
Automatically create immersive virtual tours
Effortlessly create panorama virtual tours with automatic hotspot generation, thanks to the direct integration between Corona and Chaos Cloud — no third-party apps required. Wow your clients or collaborators with customized floor plans, branded transitions, contextual details, and design elements all straight from the VFB.
Interactive 3D tour with hotspots highlighting Cozy Space and Poolside views in Corona Render.
Download Corona 12, Update 2
Precise camera control
The new Per-Camera Global Volume override (in Corona for 3ds Max and soon in Corona for Cinema 4D)lets you set different global volume settings for each camera, giving you creative freedom to experiment with fog, underwater haze, and other volumetric effects per camera, allowing you to craft distinct moods and atmospheres from various angles.
Camera control options in Corona Render showing distant and close camera fog.
Differential Ray Filtering
This improves texture filtering (reduces blurring) when the texture is seen through reflection/refraction, and directly visible textures in fisheye, spherical, and other similar projection cameras. It is enabled by default in new scenes, while existing scenes have it turned off and should show a message to prompt whether you want to switch to the new filtering. This feature has been developed as it is a requirement for Toon Shading in Corona 13.
Improved DOF for more real-world scenarios
Improvements to depth of field continue to be made, with the new DOF Highlight Solver offering reflected highlights and some refracted highlights that now behave more naturally and can be applied in even more scenarios, making your scenes more consistent and visually compelling.
A fresh batch of community-contributed LUTs
This update includes amazing new LUTs created by our community artist, Iraban Dutta. Explore them in your Corona LUT folder, and play around with cinematic, stylized, or natural tones to create powerful moods.
Four render variations of a house exterior using different LUTs and styles in Corona Render.
Speed and compatibility improvements
You’ll be happy to know that we’ve prioritized performance and compatibility in this update, making your workflow faster and smoother.
In Corona for 3ds Max, you can enjoy faster timeline scrubbing with smarter parsing when IR is enabled, only updating changed parts of the scene (this change has been made in support of rendering via Vantage using Live Link in Corona 13). We’ve added support for 3ds Max 2026, and the Vantage Live Link now has a start/stop button as well as a new progress bar to easily let you track upload progress.
In Corona for Cinema 4D, you will navigate more easily with a new Minimap in the Node Material Editor. To add to that, the Corona Converter now supports more V-Ray materials and objects, including V-Ray Clipper, V-Ray Triplanar, V-Ray Two-Sided material, V-Ray Blend material, V-Ray Geometry tag, V-Ray Proxy, V-Ray Decal, and V-Ray Enmesh.
Corona Render 12 update with faster IR reparsing for smoother timeline scrubbing.
Support for Anima 6
Bring your visualizations to life with support for Anima 6 in Corona. Populate your scenes with realistic animated people and vehicles, both with improved behavior—lifelike human movement and instant vehicle paths with wheel spin that follow traffic rules and respond to the terrain.
A centralized downloads section
All Corona versions are now available in the Downloads section on My Chaos. This change reflects our ongoing mission to streamline how you access and manage your tools.
Additional smaller improvements in Corona 12 Update 2
General
(3ds Max)
  • Added support for Max 2026.
  • Corona now detects 3ds Max environment effects and provides an option to delete them.
  • Opening a scene which references assets from the material library, LUT presets or IES presets now automatically corrects path when the location of presets changed (e.g. when moving scene between macOS and Windows, or due to change of installation root as mentioned under ‘Installation Changes’).
(Cinema 4D)
  • The Cosmos dialog can now be docked in the Cinema 4D UI.
  • Help dialog can now be docked in Cinema 4D UI also on Windows.
  • Removed usage of temporary files when rendering via TR to avoid potential issues with disk space.
Vantage
(3ds Max and Cinema 4D)
  • Improved how fast Live Link can be cancelled.
  • Vantage export / Live Link now supports light visibility in reflections.
VFB
  • VFB scrollbars are now brighter for better visibility.
  • VFB history item thumbnails now update when edited.
  • Enabled toggling of Tone mapping operators by clicking on their label (but only if they are not collapsible; if they are collapsible, then those are collapsed/expanded as before).
  • In LightMix, the toolbar and source element labels are locked and only the layers are scrolled.
  • Curves histogram tooltip displays "Histogram type" instead of "Histogram kind".
  • Added label saying where to find histogram controls to Curve editor in pop out Tone mapping menu.
  • Added missing tooltips to VFB's Auto adjustment properties.
  • Added option to reset all curves.
  • Region Draw in the VFB is now enabled when editing a CXR, but only when the edited CXR is of the same size as current/last rendering (matching the resolution is necessary for Resume Render, which is what the Region Draw would be for).
Materials
  • Added 'Only unsupported' option to Material override to override only unsupported materials.
  • Added mix alpha option to CoronaMix map.
  • Added checkbox for clamping/enabling negative values. LUTs and Curves now pass channels with negative values and modify channels with nonnegative values.
Collaboration
  • Image uploaded from history item keeps the item's name.
Rendering
  • Added the possibility to apply Bloom&Glare on the alpha render element. This is enabled by default in new scenes, but kept disabled in old scenes.
  • Added support of Intel Denoiser for Blackwell (NVIDIA 50-series) GPUs on Windows..
  • Changed installation root (on Windows) from 'C:\Program Files\Corona' to 'C:\Program Files\Chaos\Corona'.
  • Added dialog with Chaos account information (opened from System > About Chaos Corona/Licensing in Max, or in the Corona > About dialog in C4D).
  • Minor changes in the UI for data usage in Preferences.
  • Updated Cosmos service to 2025.04.04-531585
  • Updated Chaos License server to 6.2.1
(Cinema 4D)
  • It is now possible to manually release interface license for Corona from About dialog.
  • Added help links to many C4D error messages.
  • Minor changes in the About dialog.
Bug Fixes in Corona 12 Update 2
Crash Fixes
  • Fixed crash when rendering with geometry motion blur enabled.
(Cinema 4D)
  • Fixed possible crash when adjusting Filter shader in Corona Sky when IR is running.
  • Fixed crash when calling UNDO in the Corona Node Material Editor immediately after adding multiple new nodes via drag&drop.
VFB Fixes
  • Fixed slowdown when Lightmix channel is shown in VFB - up to 10x slower than beauty on some PCs.
  • Fixed highlight of checkboxes in Tone Mapping and Lightmix VFB tabs.
  • Fixed differences in Beauty vs Lightmix render channel for complex materials.
  • Fixed Lightmix looking different from Beauty when OCIO color management is on.
  • Explicitly update VFB after render stamp is toggled.
  • Fixed issue where the Lightmix context menu in the VFB was not working when right-clicking on the Lightselect names.
  • Fixed Auto adjustment results being influenced by pixels excluded from rendering.
  • Fixes issue where interactive rendering with Intel denoising was saved without denoising into history.
  • Collapsing tone mapping operator type now operates independently (i.e. not opening other operators of the same type).
(Cinema 4D)
  • Fixed issue with render queue rendering in wrong color space unless VFB render was not used before.
  • CXR layers are not added during Team Render when not needed.
Materials
  • Fixed ScannedMtl triplanar mapping moving with the camera.
  • Fix for sub-surface scattering not working on objects with decals when seen in reflections.
  • Fixed issue where applying decal on a glass object could lead to wrong refraction in the object’s glass material.
  • Fixed issue where NAN in Corona Color Texture would propagate further.
  • ScannedMtl, fixed file not rendering/displaying in UI even when it is found in 3ds Max Asset Tracker.
  • ScannedMtl, fixed "Adjust UV tiling" button being incorrectly enabled when Triplanar mapping is enabled at the same time.
  • Fixed issue where using reflection/refraction override together with black environment could lead to incorrect results in some rare cases.
  • Preview of Chaos Scans with triplanar mapping enabled now shows average texture color.
  • Corona Curvature map now correctly works for objects with intersecting elements/volumes. Legacy option was added to the Curvature shader for compatibility with old scenes.
  • Fixed issue where Corona Pattern had holes in Orthographic projection.
  • Fixed issue where translucency settings were not considered in thin mode during conversion from V-Ray material. Added condition for use of SSS color.
(3ds Max)
  • Added legacy mode for displaying the bitmaps in OCIO as in v12 Update 1.
  • Fixed missing lut/ies assets during rendering in case AssetManager can resolve them.
(Cinema 4D)
  • Fixed conversion of clearcoat strength and glossiness for V-Ray Scanned material.
  • Fixed Corona bitmap with Mapping randomizer when used on material attached with non-UVW mapping.
  • Fixed possible NaN in Scanned material.
General
  • Fixed issue where Lightmix was not correctly exported to standalone.
  • Improved the VFB refresh at the start of the production rendering.
  • Fixed DPI scaling of licensing dialog and legal agreement dialog. Fixed wrong telemetry information link and host application name in legal agreement dialog.
  • Fixed issue where adaptivity and denoising was incorrectly computed when using DOF solver.
(3ds Max)
  • Fixed color management warnings being displayed even when Corona is not the active renderer.
  • Fixed missing MaxScript names for parameters in TileMap, VrScans material, CoronaCamera, Curvature map, Chaos Scatter, Corona Pattern.
  • Fixed issue where render could be aborted when running IR and rendering bitmap in the material editor at the same time.
  • In quiet mode (batch, command line rendering) take into account whether "Show overwrite confirmation" is enabled. If not, allow VFB history autosaving.
  • Increase Corona Light viewport performance by not previewing hidden lights.
(Cinema 4D)
  • Fixed incorrectly loaded UV pattern mode in Chaos Scatter for scenes from saved in previous Scatter versions.
  • Fixed UV pattern mode not showing correct default value when new Chaos Scatter is created.
  • Fixed issues with values in Scatter lists not correctly updating for some objects when more than 8 objects were inserted.
  • Fixed issue with Scatter lists being stored in incorrect order when document is saved immediately after deleting one of the linked nodes from the document.
  • Fixed issue with V-Ray Sun remaining in the scene after V-Ray Sky/Dome conversion.
  • Improvements in hair material conversion.
  • Fixed issue with results of render queue being different for Team Render and normal render with OCIO enabled.
  • Fixed issues with incorrect color profile and view transform when using OCIO and rendering using Team Render.
  • Fixed incorrect material previews in Cinema 4D 2025.2.0 on Windows when using OCIO.
  • Fixed issues with some render passes being corrupted on save when using OCIO.
  • Fixed edge case that prevents some objects (Osds) from being visible in IR due to having a non-unique ID.
Vantage Fixes
  • Fixed Vantage live link updates when deleting object after moving camera or changing sun parameter.
(3ds Max)
  • Fixed missing update of IR/LiveLink when new objects are imported into 3ds Max.
  • Tonemapping errors are no longer shown when doing live link to Vantage.
Collaboration Fixes
(3ds Max)
  • Fixed uploaded images having incorrect gamma in Gamma color management workflow.
Download Corona 12, update 2
Download Corona 12, Update 2 here, and please share your feedback and questions in the Corona Forum. We hope you enjoy using this updated version of Corona and look forward to seeing your creations. Happy rendering!
chaos logo
Get Chaos news, tips, and inspiration every month.
Modern living room interior with a light gray sofa, yellow throw blanket, wooden coffee table with a cup and biscuits, blue rug, patterned curtains, and potted plant.
Share
Ina Iontcheva
Ina Iontcheva
Ina is a Content Marketing Manager at Chaos with a great passion for writing and the visual arts. She finds inspiration in exploring the way textures and shapes interact with each other in space.
Subscribe to Our Blog
blog-subscribe-large-cta-bg
