Save 20% off all Chaos products! Get early access.
06
13
13
23
Early access to the best deal of the year.
Save 20% off your new annual V-Ray license.
Easier to use. More powerful than ever.
V-Ray 7, Update 5 brings AI deeper into your visualization workflow, helping you explore ideas, create assets, and automate repetitive tasks with less manual effort. Discover smarter ways to work, enhanced real-time rendering, and greater realism across V-Ray Collection, all while maintaining full creative control.
Try V-Ray CollectionDownload latest version
AI that works with you.
Create stunning visuals faster, with less manual effort and full creative control.
AI Assistant
Work smarter with an AI Assistant built directly into V-Ray. Get context-aware guidance, match scene lighting to reference images with Sky Match, discover relevant Cosmos assets, and receive actionable feedback on your renders with Render Critique. Make creative decisions faster without interrupting your workflow.
Available in: V-Ray for 3ds Max, SketchUp, Rhino
Connect your favorite AI agents with MCP
Connect compatible AI assistants like ChatGPT and Claude to V-Ray, Chaos Cosmos, and Anima. Use natural-language prompts to inspect scenes, adjust supported settings, find and place assets, and automate repetitive tasks. Get more done with fewer manual steps while staying in control of the result.
V-Ray MCP is available for SketchUp and Rhino. Third-party MCPs for 3ds Max are compatible with V-Ray. An MCP server for Vantage is coming soon.
AI Asset Generation & Image Search
Find and create 3D assets faster with new AI capabilities in Chaos Cosmos. Upload a reference image to discover visually similar models and materials, or turn an image into a usable 3D model directly in Cosmos. Both features are designed to reduce the time spent creating, searching for, and preparing assets for your scenes.
More realism. Greater control.
Create more realistic lighting and volumetric effects with greater precision.
Advanced volumetric rendering
Easily refine realistic smoke, fire, and explosions with new Volume Objects, Volume Shaders, and native TyFlow Inferno support. Fine-tune volumetric effects with greater control and render simulation changes directly without exporting and importing VDB files.
New and improved V-Ray SpotLight
Create precise, atmospheric lighting with the new native V-Ray Spotlight in 3ds Max and improved Spotlights with integrated barn doors in SketchUp and Rhino, giving you greater control over light direction, beam shape, and cutoffs.
Cylinder Light
Create realistic neon signs and linear lighting with the new Cylinder Light, offering precise control over length and radius, physically accurate light falloff, and natural highlights and shadows without complex setups.
Real-time realism, taken further.
Experience the most realistic real-time rendering on the market with Chaos Vantage.
Expanded material realism in Vantage
Render more realistic materials in real time with native support for dispersion, anisotropy, thin film, and sheen. Capture the subtle behavior of light across glass, metals, fabrics, and other complex surfaces.
Advanced material detail in Vantage
Add intricate surface detail with procedural bump maps, parallax textures, and triplanar mapping. Create realistic depth and natural-looking surfaces while keeping your real-time scenes memory-efficient.
Gaussian Splat relighting in Vantage
Blend 3D models into captured environments more naturally by adjusting the lighting of Gaussian Splats to match your scene, including different lighting conditions and times of day.
Veras and Anima integration in Vantage
Bring AI-assisted ideation and realistic crowds and traffic into Vantage. Explore visual styles directly from your viewport with Veras, and import Anima projects to populate real-time environments with animated people and render your simulations in real-time.
Animate with ease.
Create realistic crowd animations faster with Chaos Anima.
AI pathfinding for crowds in Anima
Create natural crowd movement with less manual setup. Anima intelligently analyzes scene geometry and automatically generates navigation routes that account for slopes, obstacles, and crowd flow.
Waypoint tool in Anima
Guide characters through your scenes by placing a few strategic waypoints. Anima's AI pathfinding handles the movement between them, making it easier to create realistic pedestrian flows.
240 new animated 4D characters
Bring greater variety and realism to your scenes with 240 new animated characters, ready to use in your visualization projects.
Create more with AI.
Explore new creative possibilities with Chaos Veras.
New AI models in Veras
Generate videos in up to 4K with native audio using advanced AI models, including Veo 3.1, Grok Imagine, and Gemini Omni. Guide motion with existing clips, extend your shots, and refine still images with updated OpenAI models before bringing them to life.
Node-based UI in Veras
Build custom image, video, and 3D workflows with the new node-based interface in Veras. Connect AI capabilities, automate repetitive operations, and save reusable workflows for future projects.
Available in the Veras standalone application.
AI agent for 3D scene creation in Veras
Turn sketches, photographs, and reference images into native 3D models with the new Veras agent. The agent builds scene elements step by step, compares the results with your references, and refines the model as it works.
A smoother, more flexible workflow.
Spend less time on technical steps and more time creating.
Improved Node Material Editor
Create and refine materials more intuitively with improved previews, easier node editing, and direct displacement connections in the V-Ray Node Material Editor.
Available in: V-Ray for SketchUp, Rhino
Better V-Ray and Vantage compatibility
Enjoy improved viewport rendering, grass and water presets, and cluster painting support in SketchUp and Rhino. Across all V-Ray integrations, more of your materials, geometry, and lights now carry over.
Available in: V-Ray for SketchUp, Rhino, 3ds Max
AMD GPU rendering support
Enjoy greater flexibility when choosing rendering hardware with V-Ray GPU support for AMD graphics cards through the HIP platform.
V-Ray for SketchUp now in Spanish
Work in your preferred language with the new Spanish-language interface, making V-Ray more accessible and intuitive for Spanish-speaking artists and designers.
More possibilities. Less manual work.
Experience photorealistic rendering, real-time visualization, and powerful AI in one connected workflow.
Try V-Ray Collection freeDownload latest version
© Mohamed Alaa
Black Friday 2026
20% off all V-Ray plans
From Solo to Collection.
Get early access to the best deal of the year now!
